I emailed dealer I had a Mazdahandsfree reference number earlier in the week. They got back to me today and told me they are ordering the part. It should be in Monday so will schedule an install appointment at that time.
With just 238 songs it only took about 30 seconds to load.
I dont think head unit recognize any usb that is 3.0. Its for 2.0 only. Correct me if I am wrong
Thx! The squeezing part turns out to be the biggest challenge.
My label reads:
ASM# same number as yours but REV.08
S/W Rev: 07.00.000
dated 2015/01/23
But the code at top right (AMB/Z/CTA/TA/2012/3/8) still contains the year 2012!
Been a while since I posted. Upgraded from a 2013 FWD (purchased august 2012) to a 2014 AWD last June. Didn't learn about this problem until after the upgrade. Saw the posts about the TSB, stopped in my dealer last Friday with a copy. They ordered the part, it was in by Tuesday and I went in yesterday afternoon to have it replaced. Resume works as it should, but the Shuffle is buggy. Need to tap the icon and wait for it to light up and it still isn't shuffling. It wasn't really working right pre-TSB fix. Haven't had much time to play around with it since yesterday, but I 'm going to check the file/folder structure on my flash drive. I may have played around with it when I first got the car to try and get the resume working. Someone may have mentioned Shuffle issues in this thread somewhere so I'll have to take a look.
USB/iPod shuffle works after everything loads. Whereas music plays after starting the car, the display reads 1/1. It takes about 5 minutes for the 16,000 songs on my iPod to load. The display then reads 1/16000 and both Shuffle & Repeat function and the icons appear on the respective buttons. It took me a while to figure this out (with the help of this forum). Until all the songs load, the buttons (although they do not appear grayed out) don't function.
I'm using a USB 3.0 flash drive with about 2,800 songs on it. Works no problem.
Could you tell me the specific drive you are using including the size? I've tried reformatting my PNY 64 GB USB 3.0 to FAT32 once again, but no luck even with just 283 songs. I thought I'd read about other people having success with 64 GB drives, but that may have been on the 2013 model.
This is the exact one that I bought: http://www.bestbuy.com/site/sandisk...lack/9211069.p?id=1219002587175&skuId=9211069
I have around 2,800 songs on it right now. All I did was open it from it's packaging, delete the encryption software from it and then paste all the music on and pop it in the car. I'm not sure if it being USB 3.0 made it any faster, but for $14 it was cheaper than some 2.0 options at the same size.
OP here.
My module has NOT been replaced yet, but wanted to answer a question someone had.
I have the Corsair USB 3.0 64GB flash drive and it WORKS JUST FINE formatted as FAT32 (need to use a formatting tool, Windows won't give you FAT32 option with 64GB).
This is the one I have: https://www.amazon.com/dp/ (commissions earned)
I called Mazda Handsfree and got a case number, it was easy and painless. Now the dealer, I am in Canada, claims Mazda Canada has not issued a TSB for this and they will not perform any work until a TSB is issued by Mazda Canada. I simply do not get it, it is however the final straw and this is the one and only Mazda I will own - it is not that the car is not a good car it is just the feeling that a customer is nothing to Mazda, they could completely care less about ANY type of service. It is like: "We got your money, now buzz off".
Wait, what? Unless I'm understanding this wrong, it would seem the "resume" issue still isn't fixed if it just finishes the last song being played (good) but then the next track is the last track on the device (bad)?- If I let the track play out, the very next track is 1637/1637, the last track alphabetically (which with the new module, track names starting with numbers are last instead of first like they were before the update).
