Well I'm hardly the person to explain it, but I think I know the basic gist of it. Our ECU has a set maximum load which you can basically think of as being our.....volume? lol. "Ours go to 11" Anyway, think of it this way. Going wot = 10 out of a 1-10 scale. So you floor it, the ECU says ok I need to look at how much air, air temp, how much fuel, how much boost, timing, etc. to arrive at putting out a "10". A stock speed 3's boost is like 15.6 i think but thats under average/normal driving conditions. So its possible that in the circumstance when you saw your boost only going to 13 that your ECU was able to achieve max load by only using 13 lbs of boost. But I would still try and rule out any leaks or such.
