- Protege5 2003
My Christmas present this year was an Elm 323 based OBD2 scantool. (http://www.myscantool.com/). Today the son and I drove around trying
to figure out what the various real time readings meant. Luckily most were pretty intuitive. One wasn't though - fuel consumption.
The Protege5's OBD2 system gives only "fuel trim" readings, and these as percentages, which are sometimes negative. Does anybody know how to convert those numbers into units where "gallons" is in the numerator? (Presumably a negative fuel trim does not mean that gas is being created by the car and pumped back into the tank!) Eventually I want to be able to plot fuel usage versus other parameters (gear, speed, RPM).
I was also a bit surprised that the throttle seemed to have a hard floor of 10.5% Even coasting down from a high speed with my foot completely off the gas the throttle would not drop below that lower limit. That was also the throttle reading when the car was just idling.
