Yeah I think there is something wrong with my pulley system but it isn't causing a problem so I've never had it looked at.Lord_Zath said:strange. My gatorbacks were just fine w/the size given here
I've been turbo'd since Jan with this installed (last June) with absolutely no problems. The car has been run at 5000+ RPM for 2+ hrs on a few occasions with hard cornering involved and I have had no engine problems. I hope the addresses your concerns.hotrippr said:I want this mod but i am really concerned about the oil pump being underdriven and causing some trouble in the long run. Should I be concerned?
There's one bolt that YOU have to turn on the alternator that tightens the belt. It's the same one YOU have to loosen to get the old belt off. Same goes for the one on the power steering pump. There are NO automatic bolts on this car, except the ones you don't tighten properly, they will loosen automatically but not without driving. Ask again, I'll tell you the same.amsgator said:what do yall use to tighten the belts. did you just use something to push against the pulleys or did you buy the tool for it? i WAS going to do mine today but it looks like the weather wont allow.
do we have a bolt that automatically will tighten the belts or do we have to find a way to push the pulleys apart as we tighten them?
i am off again monday and if i can fingure this out i will try to install then
