benbike said:How do I retract the piston on my rear caliper? I use to own a P5 and there was a allen bolt to retract de piston...but on my MSP.....
And for the front brake I must use a C-Clamp right?
t3ase said:Use pliers and turn it back in. If you look at the caliper, you'll see two grooves where the pilers can hold on to.
Do NOT force them back in.
Chojin said:Hey Guys -
MSP DISC PAD INSTALLATION:
- Push the piston fully inward using the Special Service Tool - substitute Needle Nose Pliers for SST.
- To do this, turn the piston clock-wise until it is in far enough to install disc pads.
- Install the disc pads.
Hope this helps.
-Shawn
Brian MP5T said:You dont need to do any s*** like that.
The allen head bolt to adjust the park brake was the only thing that I needed and then it simply retracted with minimal force.
