Thats a possiblity of the re-mapping ,, but slim very slim ---take that sucker out immediatly check to make 100% certain that you have the correct battery voltage etc. and that you have grounds properly fastened and pos/neg clean and attached like new , then b-4 you crank er again check all surrounding wires etc. that you didnt pull something out or knock a connection loose . I have connected multiple batteries and this has NEVER occured - so something is wrong and its not going to magically "fix" itslef because its a computer --this would happen in seconds , not days ----do it over and make 100% sure you got everything right--when you come across any engine malfunction start with the EASIEST and most obvious thing 1st --thats would be --do you have the right battery ?, Is it connected right ? did you knock a connection loose ? what else did you do when this was replaced ...chsck that too----its a simple fix , of that im sure
