- 2011 MS3
Hey Guys is there a company out there that makes a set of polyurethen rear bushing for the mazdaspeed/racing beat rear sway. I have replaced 2 sets already. Any help would be appreciated.
Revs said:Here is what you need to get. Rear bar is 20mm so you can get the 19mm or 20.5mm greaseable set, or the 20mm non-greaseable set. I used the 20.5mm greaseable and it works fine, its not as tight of a fit as I would like, but it works. You do need to bend the brackets to 45degrees tho which is a PITA.
http://www.energysuspension.com/pages/swaybbct.html
If you still have a clunk you may have worn end links, I discovered this myself when I replaced my bushings, I grabbed the end links and yanked on them a bit and it went clunk.
