I am at 203,000 miles and I just noticed a leak coming out between the trans and the engine. I am planning on pulling the trans to see for sure its the rear main or the front trans seal. I have ordered a clutch set along with the alignment tool and both seals. Is there any problems with the flywheel that I should know? I am curious if it is common for the flywheel to crack, things like that.
