I have an old set of winter tires/wheels from my 2013 Honda Accord, and wondering if they will work on my cx-5.
They are a set of firestone winter force 2 in:
205/65R/16
Wheels are (copied from tirerack)
Offset:+42mm
Backspacing:5.39"
Bolt Pattern:Not Available
Rec. Tire Size:225/70-16
Weight:24.0 lbs.
Finish:Black Painted
Construction:2pc. Welded
The bolt pattern seems to be the same as the Honda: 5x114
Should i get a new set? Or can i use the my current set.
Thanks for your help!
205/65R/16
Offset:+42mm
Backspacing:5.39"
Weight:24.0 lbs.
