I have a 2013 Mazda5 Automatic. I have been struggling to figure out what is causing a slight rattling noise in what seems to be located in the engine. When I accelerate high speeds between 80km - 90km/h. At first I was not able to duplicate the problem, so I tried a couple of things that would hopefully resolve the issue. After looking around on the internet, it advised that air/fuel combustion could be misfiring and to try premium fuel. This did not resolve the issue. It also advised that the fuel injectors could be dirty ad might not be providing adequate fuel in the cylinders. I tried some Gumout All In One, and after this I tried lucas oil upper valve lubricant fuel system cleaner. This did noy resolve the issue.
After more investigation, I was finally able to pin down when the rattling occurs. I switched to manual mode and found that the rattling occurs when I accelerate, between 1750 and 2000 rpm on 5th gear. The rattling goes away, shortly I after it goes above 2000rpm.
Has anyones encountered this issue before? any insight is much appreciated. Thanks
