My shocks are all worn out at 72,000 miles and I'm looking to replace them all with a set of Koni sports on my daily driver 2004 Mazda 3 5-door. While I'm at it I was thinking of lowering my car (mild drop) with a Eibach pro-kit but I have a few questions...
1. I heard or read somewhere that the Mazdaspeed lowering spring kit is exactly the same as the Eibach pro-kit. Is this true?
2. What else do I need to get back to factory alignment specs after lowering the car? I know I'll need rear camber links, but if I get the pro-kit, will the Mazdaspeed rear camber links (like the ones that come with the Mazdaspeed spring kit) work fine with it or do I need adjustable ones (SBC)?
3. What about the front? I saw that Eibach has a "Pro Alignment Kit" for the front. Is this really necessary? Has anyone else needed to get one of these kits to get their 3 back to factory alignment specs or is this for more adjustability on the track?
I'm just trying to make a list of things to buy. My mind is made up on the Koni Sports. However, if the Mazdaspeed springs are the same as the pro-kit, then I can get them cheaper as a kit with the rear camber links than I can a pro-kit with rear camber links separately. Hopefully I won't need the "Pro Alignment Kit."
Any advice would be greatly appreciated! Thanks!
