OP, there are no issues with what you have, I had a CS SRI/TIP and UR catback on for a long time before I did anything else. As Somno points out, get the RMM on quickly as possible.
Then I would do the following:
AP (phone program does not cut it moving forward)
Fuel Pump replace or internals replacement
IC upgrade (I went FM, had a TM upgrade, heat soak was still bad) - Change Map
DP/TP modification - Change Map
Think about a plug change for the summer, step colder and gapped properly.
Now the fun starts.
IM PnP, change out the seals, EGR delete, 3 or 3.5 bar MAP sensor upgrade (this is next weekend for me) - Modify map for MAP change out
EM modification, BT swap, Intake swap (parts are in hand) - Modify the hell out of the map, starting with minimual boost and rich as can be, to avoid the ZOOM ZOOM BOOM, clamp the boost/AFR/timing to a reasonable numbers until a full build can be done
Meth is sitting around and will go on shortly, this will be just another safeguard, in other words I will not lean it out much for this fuel adder.
Have fun, modding is just like crack, once you start, can't stop, the nice thing is there are more options for the GENPU than there were.
I love this car, there is someone who has done 700whp on this platform, yes, severly modified but 700whp nonetheless.
