So, what to do now? Stealership service departments are closed today. Going to try ace hardware today for new screws. What should I do?
Get some fresh butterflies & screws & Red loctite the hell out of the VICS screws. Take the VTCS butterflies out & leave them out. Just hook the solenoid back up like they're still there & let the ecu think all is well. I did this for awhile until getting a 2nd manifold & doing the complete vtcs removal/p&p to it. All that s*** is for is for cold starts for less than a minute after startup. Useless bulls*** if you aren't below 0 all the time.I spoke too dam soon. Thursday afternoon... just filled up with gas next to a new white ms3. We left together. He was obliged to show me the ms3's power, and I was happy to demonstrate my car's "handling abilities" around a 90* right behind him. Well that's when it happened. Rolled up to the light and talked with him for a minute. Light goes green, and I hadn't noticed the car had stalled. Start her back up, and then I heard it. Limped her into a parking lot and onto a flat bed. Just pulled the IM off last night and my suspicions were confirmed. Failure of both screws on #4. One screw was whole, but completely flattened... Found that one inside the head (not sure what that area is called). I'm not sure where the rest of the other screw is, but I have two thin pieces of metal I pulled out of the combustion chamber itself. Searched for shards in the other 3 cylinders, but nothing. I'll try to post pics tonight. The flapper was whole, and still in the "dynamic chamber" or w/e the hell that's called.
FS section, just get someone's spare or one they've already done the vtcs removal on. Probably cheaper than trying to get parts from dealer & not thinkin they'd part up the manifold anyway. Lemme check my attic & see if the only one I have is the recall one they put in. I know I have that one untouched but not really wanting to part with it. There should be another one too IIRC. Won't be able to check it until after work tho.
So can a person take all the butterflies out and be OK? VICS & VTCS
To the OP, you are lucky as hell that all the screws were still in place & it was just the butterflies that came off.
Take out the VTCS right near the head yes but the VICS ones towards middle on manifold are there for good reason. Depending on rpms, those valves route the air thru the intake to the motor via short route for low rpms & longer route for higher rpms. This affects the torque so you really don't wanna go without it if NA. If turbo then the single route non VICS intake would help flow & not really affect torque but it matters for NA. Best bet is to red loctite the s*** out of the VICS screws & tighten them really good without destroying the brass slots (they are soft metal) & remove the VTCS butterflies or remove all VTCS parts & do light p&p on manifold to smooth out ridges where VTCS was & fill runner holes from stalk with high temp quicksteel & seal off outside hole by threading a bolt into the hole. I actually cut the stalk off flush with first runner & left the VTCS actuator in place where it looks like nothing has been done & the computer is still happy vs. it just dangling around somewhere under the hood.So can a person take all the butterflies out and be OK? VICS & VTCS
That is not very lucky at all & yes, it does sound like it is just a matter of time based on your splanation.I'm not sure how lucky I was, considering that the butterfly somehow managed to break into two pieces, one of which ended up in the cylinder. Now the engine occasionally smokes at startup, which it never did before.
I mean, it's still runs, but it burns oil like a mother now. The valvetrain makes more noise than my 4yo son, and I feel like its just a matter of time before some other problem shows up.
^ April, 2002? The recall is for 2003's, so us 2002 owners are actually suseptible to this too? My car was built 10/01...
My car has run like poo since I got it. Maybe that has been the problem all along. It smokes (burning oil) too like the OP state, though mine just does it at start-up.
How hard was it to remove and check? Scale of 1-10?
