Your saying it cost you a dollar a day to run a 220 outlet for 8 hours a day? I have a hard time computing that? What is the life span of the batteries? Where is this electric energy coming from? Did your old engine have a hole in the block? If so could you not find another block for less then 800 bucks to re use? Rather then buy something new? What are you going to do with the batteries when they do die, which they will. What if you get rear ended? Are the battery acids caustic? And 18000 can buy a lot of gas, at the projected cost of 1500 dollars a year for gas you can drive for more then ten years on that. But you are going to be able to go much further. Since your limited to 50 miles a day you won't be taking it out of town for long trips where people rack on the miles.
Get a bike for 300 bucks and be 177000 a head, use your car, truck, or hummer when it rains or you need to haul stuff
I might have messed up in my math, sorry, its about $2 per day, since it doesn't actually run 20 amps entire time, it slows down as it gets closer to full charge, plus it really depends on how many miles I run every day, which is less than 50, probably close to 30 on average. Bottom line its 1-2$ per day on average.
Batteries of this chemistry ( LiFePo4 ) last 3000+ cycles, which is over 10 years of average usage. They are dry and maintenance free, no acid there. They are 100% recycled, just like most batteries. This is safest battery type for vehicle applications, same batteries will be in Chevy Volt, whenever it comes out and in plugin Prius, whenever that comes out too.
In case of an accident worst case will be a short across the battery, which would immediately blow a fuse.
Energy comes from power plant, which can use variety of sources, granted half of it comes from fossil fuel today, but its used 3 times more efficiently than burning it in ICE engine. Power plants can and will change their source of fuel over time, but I won't have to change the car.
I am fascinated by electric propulsion and really hate gasoline, I am not a tree hugger, just hate inefficiency of a space heater with wheels ( 75% goes to heat, 25% to the wheels) and the fact that gas will run out sooner or later, very much likely in my lifespan.
I am not here to push anything, just sharing my experience, this forum helped me learn about my car and helped me reach my goal, that's all. There are plenty of forums specialized on EVs, where I am a regular poster, but since I really like my Protege5 I wanted to share with people over here.
Kstang, 100 years ago most people traveled by horse and cars didn't have much range and there weren't gas stations on every corner, so gasoline cars were probably ridiculed by sceptics like you all the time. People would probably say, I can take my horse where roads don't go, or my horse can haul its own food for long distance rides, etc.
That's fine, I am not offended at all, just sharing my personal point of view. Thanks for taking time to blow holes in my story and rain on my parade (dark)
