On my buddies 02 P5 it was the PCV valve making it smoke....
On mine the oil comsumption was the rear main seal. It NEVER was wet on the outside ofthe bellhousing. I found it when I cracked the trans case and had to pull the trans. Maybe a 1qt every 7-10k before the seal replacement.. Ever since then it uses maybe 1/4 qt per 10K oil change. The car has 265K....
