Power Window Problem
dizzi6
Need some help...I've searched on this subject, but couldn't find another thread with the exact same problem.
I have an 07 speed 3. When using the drivers door switch, the right rear window will not go down. However, if I use the switch at the right rear window, it goes down fine, no problems. I believe that rules out a fuse, and bad window motor.
Any advice on how to fix it?
Thanks for the help.
Did you end up checking the connection? I'm having the same problem. My driver side has no control over the other three windows, but if you use the switch of those window it works.
