Please help Power window problems ....
Achilles
1999 Mazda Protege LX
So i started my car today and The front passenger power window and both rear power windows will not work or go down at all. all three died today at the very same time. The front driver power window is the only one that is working and is working perfectly fine.
When i use the switch to control them to go down i can hear the clicking noise so I am assuming it must be the regulator but is it possible for all three of them to die at the exact same time ?
Or are they wired in series so maybe it is just the front passenger regulator / motor that has failed , and if i fix that one the other two rear windows will starting working again as well??
I have a 1999 Mazda protege 1.8L
Please help me diagnose this issue, any advice or input is welcome. Thanks.
yeah i figured it out . the lockout button is broken and stuck in the lock position, I can fix it though . thanks man
