Okay... long story. Thanks so much in advance for any help you can offer. This car has been a pain in my side for over a year and its not even mine.
Car started having a misfire at freeway speeds and when under higher than normal load (up hills, accelleration.) It was rare, and not a huge problem. Took it to mazda, they said coil packs. Replaced them....
Same problem.
Started systematically replacing everything. New plugs, new coils and wires (like I said). New EGR valve. Found a random jacked up piece of wiring (missing some insulation and had been messed with at some point) going to the Camshaft Position Sensor, so I found a Mazda with the same engine at a wrecker and rebuilt that part of the wiring, and also bought a new CMP.
Still same problem.
I figure it has to be fuel, since its exhibiting symptoms of either injectors not firing or some fuel pressure problem, so I bought a fuel pump today.
Installed it....And the problem got worse!
Now it is practically undriveable. It sits there, nearly stalling out. I have to step on the gas to get it to rev or move in drive, and it pulses and then drops down.
Low fuel pressure?
Part of me is happy, because at least I did something that drastically changed the symptoms. I just don't see how replacing the fuel pump would make the problem worse, whatever it is.
Could i have installed the pump wrong? It's pretty straight forward.
One question I have is how the pressure between the pump and the fuel rail is kept high. The fuel line connection to the fuel pump seems flimsy....could this be my problem?
Thanks in advance again.
K
Same problem.
Still same problem.
Low fuel pressure?
K
