mazda_sp20
- Mazda 323 SP20 (Australian FS-DE Protege)
Been a member on the forums for a little bit.
Purchased all my conversion bits off here and had them shipped to me.
This is the end result
INTERIOR
- Factory White face gauge dials,
- Factory Side and Rear skirts,
- Factory Fog Lights,
- Factory Nardi air-bag leather steering wheel,
- Factory Cloth Trim,
- Factory Climate control Air Con,
- Factory Power Steering,
- Optional Mazda clear headlight protectors
- Autometer 60mm Phantom Boost gauge with chrome cup
- Autometer 52mm Procomp air/fuel ratio gauge with chrome cup
- JVC Double Din DVD/CD/SD deck
- Nokia CK-7W Bluetooth car kit
- Mazdaspeed Protege 2003.5 Gear knob
ENGINE / MECHANICAL RELATED
- Mazdaspeed Protg 2003.5 Factory Turbo Conversion
- 114kw at the wheels on 8psi
- Currently running approx 130kw on 12-14psi with larger exhaust and intake
- Genuine Garrett GT25 (Ball Bearing) Turbo
- 1999 Mazda FS 626 Intake manifold (without internal butterflies)
- EMS Stinger 4424 v4 Aftermarket Standalone ECU with hand controller with software and
cabling
- Innovate LC-2 Wideband Controller Sensor Kit connected directly to ECU, with software, cabling for innovative controller. Accurately provide AFR from 8.0 to 22.0.
- 2.0L FS-DE Engine
- 5 Speed G-Series FWD Gearbox
- Mazdaspeed Cast 2.5 Dump
- 2.5" Exhaust made consisting of 2.5" mild steel tubing, 2.5" mandrel bends, 2.5" stainless steel cataylic converter, 2.5 Varex adjustable noise level
stainless steel rear exhaust with wireless remote control
- Mazdaspeed Radiator + Twin Fans
- Mazdaspeed Intercooler + Piping
- Injen Mazdaspeed Turbo Intake Kit
- Hardrace harden rubber engine mount kit
- Turbosmart Type III Supersonic BOV
- TurboXS Standard boost controller
SUSPENSION
- BC V1 Coilover Kit
Kit includes front pillow ball camber adjustable top plates, adjustable height approximately
50-60mm from factory standard height, 32 stage damper adjustable shock absorbers front and
rear. Customise spring rates front and rear
- Hardrace front lower control arms with harden rubber bushes, not polyrethane.
- 17 Genuine Mazda 6 Series 1 Luxury Sport Alloy wheels with 205/40/R17 silica tyres
INTERIOR
cabling
- 2.0L FS-DE Engine
SUSPENSION
