Perl Displacement Calculator
I don't know why I wrote this, but I did it a long time ago, and I remember having an intention that it was going to be used on some web page I was writing, but that just goes to show you that I've totally become distracted from that. =) Anyway, I might put it up somewhere at some point, but here's the source. By the by, I wrote this a couple of years ago. Hehe:
Code:
#!/usr/bin/perl
# Engine Displacement Calculator - Eddie Howe ( casida@bluebottle.com )
# I wrote this with the intention to implement it into command line or web
# page use, as so desired.  The -c function just concatinates data from the
# command line in the form of bore, stroke, then cylinder number. The -r
# functions as a means to do the same as -c, only designed to output the raw
# data only, for web site usage.  Do with this what you will, just please
# leave the line with my name and e-mail in.  Thanks!
my $qpi = .7854;
&sortvars;
&output;
sub sortvars {
    if($ARGV[0] eq "-c" || $ARGV[0] eq "-r") {
        our $bore = $ARGV[1];
        our $stroke = $ARGV[2];
        our $cyl = $ARGV[3];
    } else {
        print "Bore (mm): ";
        our $bore = <STDIN>;
        print "Stroke (mm): ";
        our $stroke = <STDIN>;
        print "Cylinders: ";
        our $cyl = <STDIN>;
        print "---------------------------\n";
sub output {
    my $ccdisp = $bore*$bore*$stroke*$qpi*$cyl/1000;
    if($ARGV[0] eq "-r") {
        printf "%.2f", $ccdisp;
    } else {
        printf "Displacement (cc): %.2f\n", $ccdisp;
I used values of 83 and 92... are these exact?
Bore (mm): Stroke (mm): Cylinders: ---------------------------
Displacement (cc): 1991.11
They aren't 100 percent exact, simply because the value I used for pi wasn't absoloute, obviously. But yes, 1991.11 is what the FS-DE should displace.
