PEP Upgraded Mazdaspeed Protege Exhaust Manifolds
- P.E.P. manifolds are 304SS throughout which includes the flanges, casting, and EGR fitting
- Utilizes 1/2" flanges 4 mm thick walls to ensure strength with a low weight
- Positions the turbo in the stock location
- All Manifolds include:
An O2 bung to the collector for the stock primary O2 sensor
An EGR fitting which is positioned so that you can reuse your stock EGR tube, but the tube may need some slight adjustments in position for a perfect fit.
Stainless socket Cap screws to replace the factory manifold bolts.
List Date: 2/18/2015
For more info, click here to view the original listing: PEP Upgraded Mazdaspeed Protege Exhaust Manifolds
On Sale For: $600.00
mazdas247
Thanks, and just to verify. These manifolds will work with the stock turbo as well right?
Latest posts
