Earlier this week I started hearing a noise (pissed) ( The noise is an intermittent metal on metal grinding that is speed dependent. ) coming from the front of my car. At first thought I was thinking it was wheel bearings, but I had just replaced them. So next I thought well it has to be an axle. I tore it apart the other night and the axles are both in good shape. So at this point I'm assuming its coming from the transmission. BTW, I can shift into all gears without trouble and I just recently (10K miles ago) replaced the clutch.
I'm now starting to look for a replacement differential and most likely gears. Anyone have any ideas on where to start? I found mazdaspeed differentials, but I'm not sure if I need to upgrade or not.
Also anyone know how to test if the differential is bad? I checked the fluid and its not in to bad of shape, and doesn't seem to have any metallic flakes.
Thanks,
Dave
Thanks,
Dave
