Hey guys, I'm needing to replace my passenger side mount ASAP and I'm not sure which route to go. I know I want to upgrade to poly for certain, and I'd love to have AWR mounts, seeing as everyone here swears they are the best, but my check wallet light is on right now and I can't squeeze out $350 for 2 mounts shipped...My last ditch effort option is to pick up new rubber mounts and do a cheap window weld fill on them, but I'd rather go with a solid poly mount before I do that lol
I've read a handful of threads around the forum, and it looks like my only other option is either SpeedUnit or SLS Performance. I'm a bit on the fence about both of them though, and which one would be the best option, or if I should just hold out and go with AWR for all 4. The car is a daily driver and spends a lot of time on the highway in traffic. Right now with the blown mount, I'm having issues spinning my right wheel on dry pavement with 65% tread tires...
I understand poly is stiffer and transmits more vibration, that isn't a concern, since I intend to poly the rest of the suspension and lower the car in the future also.
So from what I can tell, the SU mounts are made from billet aluminum and come factory with 68 duro poly (which past experience is close to factory rubber in feel and stiffness). The SLS mount looks to be a much sturdier steel mount and seems like it would hold up to a bit more abuse (passenger side). I found the latter on ebay for $140 with free shipping, and the SU mounts come in a kit (L/R) for $289. I like the fact that the SU mounts are lighter than stock and shave a bit of weight off the car, but that passenger mount design looks a bit weak...
Any suggestions?
Any suggestions?
