Driving the P5 home from work the other night I sat for a while at an intersection, and when I got the green, I shot across the road, looked down at the gauges, and noticed the temp gauge was all the way to HOT!
I backed off the throttle, and drove slowly the 1/2 mile home. I turned the heat on, and the temp fell back to a normal range. Since then, I've driven the 3rd car to work.
Today I read a bunch of threads on here about diagnosing overheating, then took the P5 out around the neighborhood to try to figure out what's going on.
It stayed cool for quite a while, but eventually it got hot. Once the needle moved off of the normal range, it climbed VERY rapidly to full-hot.
At one point when it went full-hot, I pulled over, jumped out, went to the front of the car. I could not hear the fan running.
Another time, the cooling fan came on when idling in the driveway, and kept the gauge low, so I know the fan/switch/relay isn't completely shot. Both fans come on with the A/C.
The radiator hoses are both hot, making me think the problem isn't the thermostat.
Coolant is at the proper level, and isn't boiling, overflowing or super hot in the bottle.
So: What the hell?
Could the temperature sensor be failing and not telling the fan to come on, but only sometimes?
Could the thermostat be failing and not sending coolant through the radiator, but only sometimes?
Could the Fan switch be failing and not turning on the fan, but again, only sometimes?
More importantly, how can I figure which one it may be, without replacing all of it?
Thanks for any suggestions. I'm a bit baffled.
So: What the hell?
