How long should you warm up the engine in cold weather (below freezing)? I want to keep my MS3 past the warranty expiration. Should you not start driving until the temperature needle starts moving?
LMAO! Why wouldnt it last past the warranty? Beating your car much?How long should you warm up the engine in cold weather (below freezing)? I want to keep my MS3 past the warranty expiration. Should you not start driving until the temperature needle starts moving?
I am religious about letting a car warm up. No matter what, everytime, I let my MS3 as well as my Toyota truck, Audi, and Trans Am (when I had them), warm up until the needle has moved, and I will not shift above 2,500 until it is fully warm. I really dont think all this is necessary, but I have never had a car problem yet (knock on wood) and whether or not this is the reason why, I dont want to mess with it.
If you dont have the time to wait, just dont beat on it until it's warm.
i think some people are a little outrageous to be honest i dont have the time or wanna waste my gas by letting my car run for 10 mins and as long as you have the correct weight oil in and you dont beat the hell out of it right off the bat its no different than summer driving just use your head
On cold mornings I usually let the idle revs fall until about 1250 or 1000. It doesn't take too long to warm up after that. I definitely wait until it is below 1500 though.
After seeing the post below mine, I also shift no higher than 3000 until the needle has moved to the middle position (or just below as I dont think it is ever in the exact middle)
Idleing your car to warm it up is a bad idea. You think everything is nice and toasty but you're only half right. The motor might be up to temp but the trans isn't. Best bet is 10-20 seconds to get the oil moving then drive it and keep from high revving for the next few miles and you'll be fine. Switch to syn's and the oil will flow sooner as well.
ooo...i didn't even think about the trans. that's a really good point...sux, but looks like i'll have to be a little more careful...=/
Waist Gas ? Life isnt that rough!
Warm her up and cool her down. A must for any FI driving
