A AbsoluteSwed Member : Protege 5 May 23, 2005 #1 Ganna get an oil pressue gauge, just wondering if i should get the 100psi one or the 150 psi (guessing 100 will be fine but), also wondering about what are the regular proteges oil pressure.
R Ryoga28 Member May 23, 2005 #2 Just to give you an idea, on the Msp, the oil pressure during idle (warm up) is about 19 to 20.
A AbsoluteSwed Member : Protege 5 May 23, 2005 #3 have any idea what it is at WOT, guessing i will fine with the 100 regardless right?
R Ryoga28 Member May 23, 2005 #4 During a cold start the pressure is roughly 80ish. After warm up, at wot, maybe 50-60ish... I'm taking my oil pressure off because of recent problems with oil leaks.
