Just want to verify the part numbers. Are these the correct ones?
AT 2 pedals - BHN2-V9-091, BHN1-V9-093
Footrest - BHN1-V9-095
How differently does driving on the aluminum pedals feel? Do your feet slip at all? I love the look but not the price. I'm thinking of at least getting the foot rest because I hate ruining that carpeted area with dirt and dust. I didn't understand your installation procedure clearly; is it difficult removing the plastic trim to get to the styrofoam? Thanks!
There really isn't much difference in feel on the drive pedals IMO. My biggest gripe with the car is that it didn't have a dead pedal. (even an el-cheapo plastic one) The dead pedal does have a bit of raised aluminum for a shoe to grip and feels nice and sturdy when you put your foot on it. Especially compared to pressing the carpet which had some give before it would hit the styrofoam behind it.
I ordered the dead pedal yesterday using my credit card points. maybe some time down the line i'll get the two other pedals, but it's not a priority.
How is it installed?I have these, 80% less price, NO drilling and very good.
https://www.amazon.com/dp/ (commissions earned)
Sent from my Nexus 6P using Tapatalk
For the footrest, you don't need a "drill".Hi OP,
I was wondering if you could recall your install for the footrest. Did you really not need to drill for it? If i don't have to drill would be nice otherwise i'm heading to orchard supply for the 5mm drill bit. Thanks!
Just a knife to cut a hole in the carpet. Underneath the carpet, the footrest area is styrofoam. The screw goes through the carpet and into the styrofoam.
Cool thanks! I found it kinda difficult to cut through the carpet but finally managed and after that was easy. I ended up just picking up 5mm drill bit so i went ahead and used it. by drilling it was helpful to keep the nut plate in place.
Where did you find a metric drill bits? Can't seem to find anybody locally that carries anything but standard sizes. It's like I am an alien when I ask for metric. lol
I have the full pedal set to install and it calls for 2.5mm, 5mm and 7mm between the accel pedal and the footrest.
Edit: Found a fairly inexpensive set on Amazon. Good to have around, even though it's more than I need...
