yes, you need to wire in a "MIL eliminator", there is a how to, do a search and you should find it pretty easy. You can also use the spark plug non fouler trick, a search should bring up plenty of how to's on that.
the reason it comes on is because your removing the first cat converter and the second o2 sensor is going apeshit
