OBDII Readers & Apps.....what do you use?
2012 Mazda CX-5 GT 2.2L Diesel AWD
With the advent of modern technology and very cheap electronics & apps, what monitoring apps are you using and what do you like to look at. I don't monitor the car all the time, I just use it every now and then just to check 'whats going on'
I have the Forscan app using a mobile phone to read all the data. Dashboard is as follows:
Battery Voltage
Engine Coolant Temperature
Engine Oil Pressure
Engine Oil Temperature
Distance traveled since last oil change
Total number of DPF Regens
Amount of Particulate Matter generated (g/L)
Distance traveled since last DPF regen
DPF Regen ON/OFF
Exhaust Gas Temperature
Gear Position
Rear Differential Temperature
Transmission Oil Temperature
Torque
All a bit of cheap fun that one day could save you thousands of $$$$
I don't have it yet, but I'm planning to purchase an Ultragauge for the CX-5. I used to have one on my Speed3 and it was great for daily live data monitoring. I also have an OBD2 Bluetooth adapter that I use to monitor using an app on my old Windows Phone and using Torque on an old android phone.
bumping this can you folks send a link of the specific OBDII readers you are using? there are quite a few on Amazon just wanted to know which one everyone prefers.
Thanks!
Does not apply to Mazdas but I use OBD11 for code reading, live data reading, bi-directional output tests, and coding and adaptations
Latest posts
