Boilermaker19
- 2003.5 Mazdaspeed Protege
I have never had a turbo before, much less one that has been modified as mine has, so I have a couple of questions; First, my boost goes all the way up to around 15, which scares me a little. I have the FMIC, 3" exhaust, cat delete, split second (I am running the FMIC map from this forum). I think I should limit it to about 10 lb of boost, but I have no idea how to do that. Second, in second gear, if I am really punching it and the boost swings up to around 15, the car will cut out repeatedly, but then get back to running. This only seems to happen when I am really punching it in second. I only recently bought the car, and, frankly, I have found a couple of switches the purpose of which I am unsure of, and a cable that is just coiled up and unused. I have not found a turbo timer or wideband, and I apparently need to run a new oil pressure gauge, but any ideas on the sputtering and controlling my boost? If I keep the boost around 10 with the accelerator, she pulls great.
