RyanJayG is indeed correct.
Tein Flex coilovers. 16 way adjustable shocks with ride height adjustment and pillowball mounts. You can adjust the ride height via raising or lowering the shock itself. Or, for that ultimate slammed look, you can dial out spring height as well.
I am currently setup to 12" front and 12.25" rear (center of wheel to fender) which is what my H&R springs were at. Spring rates are 392F/336R. I am getting it aligned on Thursday.
But... I have put on over 200 miles, so I have some semi-impressions...
Car turns incredible. Its almost like it helps turn the car better. I have manual steering, so the car always felt rather heavy to me, but with the Tein in, it turns great. The ride is MUCH better do to the increased travel length. Before, crossing railroad tracks at speed would cause my KYBs to bottom out. Now, the Tein just soaks the bumps up. It is stiffer than normal, but not objectionably so.
Issues - the rear of the car feels twitchy now, almost unsettled. It is very subtle, and impervious to anybody else that drives the car. I am messing with damper settings try to get the nervousness out of the car. Its not undrivable nervous, you can just feel the rear hunting a little bit at speed.
and OMG - is this thing tail happy. I have no problems getting the car to over rotate, and this is on the street. Tail out driving is fun, but this is almost ridiculous! Like I said, I started at the recommended damper rates, which were 8F/8R (from full hard) so I am experimenting with 4F/8R. The car is more planted, but I have only driven it this way for 10 miles.
A couple of peeps on miata.net recommend doing just a front swaybar with this setup. I still think I can dial out the nervousness with damper settings, and a re-alignment. Furthur nervousness can be dialed out with tire pressure.
The best part - the car is so FLAT in a corner. Its amazing the way it grabs the road and just corners! The few times I had the tail out, it was VERY easy to catch, not like my old setup where once the tail was out, you had to carefully manipulate the throttle. With the Tein, its just a little countersteer and you are good to go!
My first track event will be July 10th and 11th. I am going to Streets of WillowSprings. My fast time there, I believe, was 1:44.7 on my last suspension, so we'll see if better ride and more travel will also equal faster lap times
-Danny
