A
AustinG
2003 Mazda Mazdaspeed Protg
General
Vehicle Type: 4-door sedan
Driven Wheels: FWD
Pass. Capacity: 5
Price Range: Est. $20,000
Assy. Point: Japan
Engine
Layout: Transverse mounted front engine
Configuration: I
Cylinders: 4
Displacement (cc): 2000
Bhp@RPM: 170
Valve Gear: DOHC 16V
Boost: Intercooled turbo (Garrett T25)
Fuel System: multiport
Transmission
Type: Manual
# Gears (excl Rev): 5
Limited Slip: Std
Suspension
Type - Front: MacPherson strut/lower arm
Type - Rear: Double A-arm
Fr. Susp. Links: anti-roll bar
Fr. Damper: MacPherson Strut
Fr. Springs: Coil
R. Susp. Links: anti-roll bar
Rr. Damper: Twin-tube shock
Rr. Springs: Coil Wheels/Tires
Speed Rating: Z
Tire Brand/Mod: Bridgestone Potenza RE040
Tire Size F/R: 215/45ZR17
Whl. Size (in.)/Type F/R: 17 x 7 Alloy
Brakes
Type - Front: Vented Disc
Type - Rear: Disc
Power Assist: Vacuum assist
ABS: Opt
Stability Control: N/A
Traction Control: N/A
Pass. Restraints
Airbags: Dual airbags
Seatbelts: 5
http://www.velocityjrnl.com/jrnl/2003/v2kmdl6480ovw.html
General
Driven Wheels: FWD
Pass. Capacity: 5
Assy. Point: Japan
Engine
Configuration: I
Cylinders: 4
Bhp@RPM: 170
Transmission
Type: Manual
Limited Slip: Std
Suspension
Fr. Springs: Coil
Speed Rating: Z
Brakes
Type - Rear: Disc
ABS: Opt
Pass. Restraints
Seatbelts: 5
