doubleKlutch
- 2002 Mazda Protege5
Hi all, I just bought a 2002 Mazda Protege 5 (Base, I assume) yesterday. It drove really nice for a $3500 car, so I bought it, but I've noticed some odd things over the last few hours. I also drive a 1999 Protege with the 1.6 DOHC motor, and the comparison is strange.
-Pinging? There is a mild pinging under moderate load at low-mid rpm. I didn't notice it on the test drive, and I suspect the previous owner may have used higher octane fuel. The tank was empty when I bought it and I filled it with 87. Is it normal to ping at low rpm and not high rpm? Wiki's article on 'knocking' (spark detonation) implies that it should ping worse at the top end.
-Suffocated powerband? Compared to my 1.6 '99 Protege, I was expecting a bit more power. Maybe the '02, in wagon form, is heavy enough to cancel out the extra 0.4 liters. It certainly has more grunt at the bottom end. But at about 4k rpm, it just seems to plateau and run out of breath. My 99 pulls hardest at the top end, but the 02 just seems to die out. Are the 2.0l cars engineered for low end grunt? It almost feels like the 02 2.0L P5 is slower than the 99 1.6L sedan. Is that expected?
My initial thoughts:
-I bought the car from a shop that claimed that recently did the 150k service and a timing belt. I'm wondering if the belt might be off a tooth?
-Or maybe the Cat is clogged? That would restrict top end power and might that raise cylinder temperatures enough to ping lightly? Are there any tests for a clogged Cat?
-The manual recommends 87 octane fuel (or higher), but I think I'll try a tank on 89 or 91 and see what happens. Gotta wait for an empty tank though...
-Should I worry about doing any damage while driving the car, assuming that it is suffering from power loss and detonation?
I've got less than a 100 miles on the car so far. I'll do some more driving today and see if I can add any details later.
Thanks for any ideas.
