iwkauralain16
So i am in a bit of a bind...
the other day when i was driving to work, i heard the sound of water and it almost sounded as if i were on a boat... well i looked at my water bottle and that wasn't what was making the noise....
I feel underneath my passenger seat to see if there were more water bottles down there and low and behold, my car was flooded on the passenger side :-/ So i turned around, called into work and told them what was up, and took out the cushion(becuase I wasn't strong enough to unbolt the entire seat... heh) and used hte shop vac to vacuum the carpet and get the water out. WEll, it was PLENTY wet underneath the carpet, and I couldnt get to it all.
I have no idea where the leak is coming from, i did get hit on the side not too long ago but the other vehicle only brushed up against me and you can barely see the damage. I want to just unbolt my seat, and pull up the upholstery so i can find out where the hell the water is coming from but have no way of knowing how to do this. can anyone give me a little help here? My car is still wet underneath the carpet. Meldew... I don't want to have any of that. I had my sister spray my car with a hose and i did not see the water seep in from the edges of the door, so it is coming from somewhere else...
Thanks!!
-Val
Thanks!!
-Val
