Hi everyone,
I've been reading for a while on this forum and this is my first post. I usually find what I'm looking for with the search, but the problems I'm having now are maybe too complex for this.
For a while I've been having CEL light coming on and off and now I finally got around to get the codes out. There are the following :
P0110 : Intake Air Temperature Sensor 1 Circuit
P0100 : Mass or Volume Air Flow Circuit
P0115 : Engine Coolant Temperature Circuit
P0120 : Throttle/Pedal Position Sensor A Circuit
P1600 : loss of KAM power, circuit open
Is there a single problem that could explain all of this or is it all seperate ?
Anybody as an ideal of what my problem(s) might be ? What should I look at under the hood ?
My car is a stock 2003 protege5. The EGR as been changed and I got the revised model. I do all the regular maintenance on my car.
Thank you
Thank you
