njintau_fsd
- 2003 Mazdaspeed Protege
What's up guys:
So I installed a Prosport Performance 52mm Electric Oil Pressure Gauge (Amber/White) (216BFWAOP270PSI) in my MSP a little over 6 months back. The gauge ran fine for a month or two then started giving me weird readings. First, it would show oil pressure at 20-40 psi, (sometimes 60-80) at cold start, then after the car had warmed up, it would drop to zero. If I ran the A/C, the needle would either go to max or jump around. Thinking that it might be bad wires, I replaced the wires I used before with 16AWG insulated Stereo Wire and grounded the sender at the strut tower post by the battery and grounded the gauge in the cabin by the fuse box. Now it doesn't even run although it lights up and does the needle sweep just fine. Doing some research, I found a lot of angry reviews on prosport gauges, specifically the senders, which has me a tad worried.
So, my questions are:
1) Has anyone else installed this style of gauge before? Were there any issues? If so, were you able to fix them and how?
2) Are there any tests I can run to root out the problem?
3) If the sender is to blame, is there a another model sender I can use in place of the one that came with the gauge?
Btw, I used 16 and 18 gauge wire along with inline crimp connectors. I checked and double checked for any loose connections and I've checked the grounds, they're fine as far as I can tell. Once again, the gauge lights up (both colors) plus does the needle sweep, it just doesn't do anything else now.
I would really prefer to keep this gauge because 1) I like the way it looks, 2) money is tight and I don't have any on hand to buy an Autometer or an HKS.
Thanks in advance!
Thanks in advance!
