No, it's nothing to do with my engine, I'm sure of that.
It started a while ago, not long after I changed brake pads on all 4 corners, which makes me think I might have disturbed something whilst doing the job.
I'm fairly sure I did a proper job as the brakes actually work great - no grabbing or pulling, very solid feeling.
Now the noise happens at various times - sometimes when accelerating gently, often when braking and going round a slow corner at the same time, but never when braking in a straight line (no matter how hard).
I _think_ it is coming from the rear somewhere, and it's almost like the noise a knackererd cv joint makes (a fairly noticeable "click"), which can sometimes be felt through the actual floor of the car.
As the noise started after doing the brakes, I reckon it's something to do with someting I might have done (or not done!)
Does anybody have any suggestions as to what I can check or what might be causing this? I torqued every bolt up properly, so it's not loose lug nuts or anything stupid like that.
Thanks.
Thanks.
