Need help with gauge install
Okay, so I'm 3/4ths through installing the Prosport gauges (done oil pressure, A/F ratio, and Boost setups and wirings). All that's left is the illumination, ignition, and ground wires. ground is simple: connect to bare metal. As for illumination, i want white lights in daytime and amber at night. Thus, I read that orange wires (for amber lights) can be tapped into the orange with black stripe wire going to the radio which is the signal for parking lights. For the white lights, i'm not sure where to tap to as I'm afraid it would cause complications with the amber lights. As for the ignition wire, I'm thinking of tapping into the cigar wire (red, IIRC) since i got the radar detector setup done there anyway.
Problems: where to connect white wiring to?!
