Try to follow me here, because it's rather complicated and has a few scenarios.
So I've got my 2001 MP3 which is having trouble starting. I'm going to point out right off the bat that I've got a failing alternator and I have a replacement just waiting to be installed by a friend (can't afford a shop). I don't know if it's related, but there is a problem with the sensor in the driver door that makes the car think the door's always open unless I slam it hard a few times.
That being said, here's my issue:
For no reason whatsoever, and usually unpredictably, when I turn the key to ACC, everything on the dash lights up ok. As soon as I turn it to the ignition position, everything dies. I completely lose power, to the point that my radio even loses all its settings. Takes anywhere from 30sec to a min to even regain my odometer, at which point there's no juice to do anything.
So when this happens, I connect my handy jumper-pack to the battery (which I now keep in my back seat at all times) and one of 3 things happens:
1) Same thing happens again.
2) The car starts normally.
3) The lights on the dash stay on even when I turn the ignition to start. When this happens, through trial-and-error I learned that I needed to set my alarm off (factory alarm) and then hit unlock on the remote to get my ability to start back.
These 3 things have no particular pattern of happening, it's completely random. For instance today, I drove to the gas station with no issue. After filling, I had to jump it (scenario 3). Drove home, turned the car off. Waited 5 mins and test-started without a problem. Went outside to go out 6 hours later and I can't get it started (scenario 1).
A few ideas have been floating around when I asked people about it:
-Bad starter.
-Ground problem with door sensor that's draining the battery.
-Alarm system is defective and the ignition-kill is grounding out.
-My car hates me.
I'm reaching out in desperation to see if any of you have had similar experiences or could offer some insight. I'm a computer guy, not a car guy.
Thanks in advance!
-Brian
-Bad starter.
-My car hates me.
Thanks in advance!
-Brian
