Not hard if you are comfortable with reading wiring diagrams and using a voltage tester. You would need to buy a simple switch (preferably, a lighted one) and run the fog light positive voltage wires to the switch (which receives voltage from a live source). The negative wire needs to be connected to a good chassis ground (or to the battery ground).
