Pull the wire that is in the middle(top portion) of it. Remove with a deep socket. Install in reverse order.
Oh ok have you done this before? It"s not as easy as your making it sound. Are you aware of how difficult it is to get a Socket on this thing? You can burn your hand trying to do so until its cool.
Forgot to mention I replaced mine during my oil change while the oil filter was removed. Lots of space without the oil filter in the way.
i too did mine during an oil change and it took an extra 10 minutes i believe i got to it from underneath
Thanks guys for your support this helps me out alot. Ill let you know how it goesI did it this way, from underneath. Took very little time to remove and replace.
I think I may have the same issue, when you say "Reverse order", do you just mean take it off and put it back together??
Yes, put the new unit in with the deep socket and plug the wire back in.
You forgot to mention to put Anti Seize on the Oil sending unit threads so that it doesn"t rust up and it stays protected better
I couldn't remember if the one I got had some coating on it or not.
Did you end up replacing yours?
