Hey Guys here is my new Beck Arnley Fuel Pump I spent a good 3 hours getting this off and on the car the biggest pain in the but was trying to remove the Fuel line clips off of the fuel pump with out cracking the Fuel nipple that they come off of. I had to use a pair of needle nose Pliers to remove them off the car because i didn't have the right Fuel hose removal tool. It's amazing that i didn't crack the fuel Nipple off of the Fuel pump. All said and done it was a six hour Job because i realized that i forgot to install the Fuel pump Plastic casing that covers the Fuel Filter so i had to take everything back out and do it all over again i hated that part but im glad i got it done! Well any how the Fuel Pump is up and Running fine the car smelt like Gas for a day because i had to remove the fuel hose's and some gas spilt out a little bit but other then that there"s no leaks and everything works fine thank God it's done! Here have a look at the before and after pictures at the bottom. Just look how stained the Fuel filter sock is its puss yellow compare to the new Snow white one. Oh and i also replaced the Yellow Fuel clips and Fuel pump gasket and Fuel pump black metal bracket on the top and i replaced the new screws on the top as well because the old ones were extremely rusted. Now hopefully ill be able to get better gas mileage with a new fuel pump and a new Fuel Filter Oh yeah!!!!!
Check out the new pictures below.
