I have a PA5422 4 channel amp. Does anyone know if it is stable to bridge two channels together at 2 Ohms? And how many watts that would probably produce?
Also if anyone knows where I can get a manual for my amp online?
Below are the specs:
PA5422: 4/3/2 Channel Power Amplifier with ChannelFlex Crossover
* 200W 4 Channel Max. Power Output at 2ohm
* 120W 4 Channel 0.1% THD at 2ohm Stereo,
2020,000Hz@13.8V (RMS Continuous Power)
* 85W 4 Channel 0.1% THD at 4ohm Stereo,
* ChannelFlex Crossover High-Pass Crossover (12dB/octave, 120Hz)
Adjustable Low-Pass Crossover
(12dB/octave, 50200Hz)
Adjustable Pre-Out High-Pass Crossover
* Subsonic Filter (050Hz)
* Free-Flow Signal Circuit
* Double-Sided PCB
* High-Current, High-Speed Output Devices
* High-Efficiency, High-Energy MOSFET Power Supply
* Audiophile Grade Component Selection
* Intelligent 7-Way Discrete Protection Circuitry
* Music Reproduction with Low Distortion & Ultra-Low Negative Feedback
* Efficient Cooling with Low-Profile Heatsink
* Multi-Mode Configuration
* Stereo/Mono Switch
* 2ohm Stable Design
* Double-Sided PCB
