GMalatrasi
- 2003 Mazda Proteg5, soon to be Turbo
I've been trying to troubleshoot the issue for a couple weeks now.
Symptoms:
After car is warm or I've been riving for 15-20 mins, the shifter gets more and more difficult to move. It becomes difficult to put into a gear, to get out of a gear, and even herder to move the lever laterally from the (1,2) position to the (3,4) position and vice-versa.
Attempted Fixes:
1) Disassembling and inspecting shifter for wear.
- Everything was like new, no wear marks, no rust, nothing to indicate a problem.
- Lubed everything thoroughly and put it back together.
- Issue persisted
2) Inspect shifter linkage under car. (Both at the shifter and the tranny ends).
- Again everything looked fine, no unusual wear or rust.
- Again sprayed everything with penetrating, waterproof lube.
- Issue persisted
3) Check for missing exhaust heat shields that might be overheating the links and/or bushings.
- No shields missing or broken or misplaced.
4) ...? Nothing left to try outside of the transmission itself.
Anyone have any ideas?
Anyone experienced a similar issue?
Reminder: it only happens after driving for a bit and car is warm.
Symptoms:
Attempted Fixes:
- Issue persisted
- Issue persisted
