SGT_OKINAWA
- 2010 Mazda CX-7
Okay, not to sound like a d!ck _||_ here, but I've
got to lend my .02 worth to this thread because
we can either tell lindsayt (Whom we've not heard
from in a while) to go to a repair shop or dealer and
seems Mark787B has taken up this thread as his own,
(No problem at all, but we have to remember, all cars
are NOT the same even right off the assembly line cars
are not the same)
Now having said that.
I'm surprised no one has mentioned the condenser,
heater coil and other fluids.
Now hear me out...
cars have fluids and oils sloshing around in
them all the time, and at times oh lets say
on A HILL (hint hint) and / or when accelerating
fast (hint hint) those fluids and oils get into/onto
/around/between places they normally don't and
that can cause some metal to get hotter than normal
and oh here it comes..... burn off some 'oil' and make
a smell.
Take for consideration the heater core:
That this has lubrication oil on it from the factory that is there to keep it from rusting out during shipment or delivery to the customer.
or take for consideration the AC condenser:
same applies to these, it's covered in a thin oil to keep it from rusting.
Well these two out of many more things, could get hotter and colder and give off a smell FOR A LONG TIME.
I had a Isuzu Trooper that after 100,000 miles I reved up the engine to get the batter to recharge as much as I could (Yes alternator was going out) so I could be safe diving it to the shop to get it fixed and whoa did it ever smell like burnt oil when I turned it in, guy asked "You ben racing this today?" (hahaspit)
More: The plastic under the seats that carries hot air to rear, has a thin coat of oil, well on a hill maybe the hotter water is higher in the engine block, thus getting more heat to the heater coil and giving a little bit of a boost in heat and....welll you get the idea (toetap)
Now consider this, are you using recycled air flow (You know on your AC controls) or fresh air, probably not fresh air because it's 100 below zero this time a year. (sick)
It was posted that someone took theirs to the dealer and they said CLUTCH is fine, and trust me the clutch use could go on for days in this thread, heck even years because, *drum roll*.,,... all cars are different (confused)
I'd give ANY NEW car time to 'settle in' and go a FULL 4 SEASONS before you claim lemon on a new car.
Now if it were SMOKE or MIST, then I'd be really concerned.
Peace(rei)
are not the same)
Now hear me out...
a smell.
Peace(rei)
