MS3 Wiper fluid nozzles jacked?
Jasonstiller
Mazdaspeed 3
Tried using the wiper fluid on the front windshield and the fluid just oozes out. Is this something I can take care of myself or do I have to take it to the dealer?(uhm)
You can take care of it yourself if the lines are loose or nozzles / lines are clogged. If the pump is bad, you COULD take care of that yourself but I recommend you leave that to your warranty.
if it's clogged.... just take a small pin and scrape the inside of the nozzle.... you may have the realign them using the pin to aim them
but first, make sure you have plenty of fluid in the reservoir
I am having the same issue with my rear washer nozzle on my MS3 and my wife's Focus. I have already replaced the nozzle on the Focus, but that didn't fix it.
My front nozzles don't work and the car is a month old. I used them at least once before and I just topped off the reservoir. I guess I'm going back to the dealer next week. (headshake
I guess it would help if I pushed the lever in the right direction. (bang)
Turns out the problem was the interface between the steering wheel and the driver's seat. (braindead
Latest posts
