- Banned For Being A Troll
So, No Shock. My AWR pan leaks out the welds.
(I was assured that Tony had fixed this problem, but he apparently could not figure out the most basic welding techinques.)
Seriously hard to believe that something that was $400 + dollars cant outperform the Hunk of crap OEM pan..
Pan Plan.
Media Blast Pan
Weld inside and outside (TONY!!!)
Machine mating surface (Because it is warped to s*** TONY!!!!)
Coat pan with "Bluing" (used on assault riffles)
Media Blast windage tray
Install second AN10 Fitting for DOC B Oil Return
Machine both sides of windage tray true
Install windage tray and modified oil pump to engine block with Permitex "Right Stuff" gasket maker.
Install oil pan to windage tray with Cork Gasket
