Great info, but really any forced induction car you should expect to blow at any time, it never blows up because you ran it hard once or twice they tend to blow because its run hard all the time. Even at stock boost tuned well if you rag on it all the time it won't make it to 10k miles
It's all in how you drive your car and care for it, unless its an NA Honda, you can rag the s*** out of them for well over 100k miles and they will want more
All true...save a rotary engine...those can be expertly tuned, make great power, and last for 100k...yet a single ping can send it sideways out of the front of the car...well not that really, but ruin the apex seals instantly and its over...even though there was no previous damage leading up to the failure...
The best way to think of any 'performance' engine's life expectancy is from the heat direction, only exception being ignition timing..which is only partially heat related...but fuel tuning is 100% heat related, that is exactly why it needs control...
heat is what will ultimately kill any engine...the misconception starts with most owners starting out with 'i want more power', and focusing on how to get the numbers...and thinking a water cooled engine will keep itself in check, heat wise, no matter what...occasionally you see upgrades to radiators, some 'water wetter', stuff like that...but essentially coolant is only a portion of what needs to be cooling the engine when driven hard...
Oil and intake charge is actually better at cooling critical components than coolant ever is...coolants there for the block and head...thats about it...In fact the block itself is usually iron simply to act as a huge ass heat sink, not just for the strength...some blocks are aluminum or some exotic material, but they'll nearly always have iron sleeves pressed in for heat sinking the chambers...the coolant is a secondary agent for cooling what absorbed the heat to begin with...
but oil is inside the engine with its face in everything the whole time. keep that oil cooler than the block, and it too will absorb and suck out more heat with each cycle...Same with air and gasoline...even on a hot day, that stuff is less than half the average temp of the assembly inside the engine (again AVERAGE, there is localized heat over brief periods spiking 500 degrees)...nice cool air, a spray of gasoline, and cooled circulating oil will suck out WAY more heat, and much faster, than the water system can...and more importantly...it'll absorb it at the locations the water never gets to...
jdwk is exactly right...Since this is MSP related, i'll leave the NA problems of high rev friction and associated heat out of it...Ideally a goal for FI should be a power number with as little boost over ambient as possible...you can get to 200whp many different ways...some ways will be a 100% grenade...proper ways will make the engine possibly in a better state than it currently is...power is a derivative of torque, and torque, from a internal combustion engine, fundamentally IS heat...thats how this whole thing comes around full circle...Its heat management within the engine that determines a given power output from the same assets (same amounts of fuel and oxygen)...
