Misc turbo parts
Status
Not open for further replies.
95blkprobe
95 Blk Probe/ 02 Blk Mica P5
Here are some turbo parts that I have no use for, I will add more to this thread as time progresses. All items are OBO AND + SHIPPING.
Turbosmart Boost Tee Boost Controller (new) - 90
Magnetic Oil Drain plug (BNIB) - 15
Dual Gauge Pod - 15
Autometer gauges - 17 each or 35 for all
Acid ported and polished fuel rail with AN6 fittings - 90
Custom Yudkib Vacuum Block (new, unused) - 30
Oil filter relocation piece (attaches to back of block) - 15
SignatureSound Catch can (Snot Box) (new, unused) - 40
Phenolic TB spacer w/ hardware (brand new, unused) - 50
SS Oil feed lines AN3 - 20 each ONE LEFT
So the turbo needs a rebuild? just turbine seal?
I assume that this is a external wga application?
Hmmmm
Yes. The turbo is setup for external wastegate. I also have the cast piece for it that you could run internal wastegate but you would have to source out your own wastegate.
bump for brand new lightweight crank pulley and throttle body spacer, now including shipping!!!
Status
