Macadonious
- Maxda3
I have noticed that the M3 rear likes to slip out from time to time around hard corners. The car does not lean that much nor shift weight too much. The only thing I can accuse the car of doing is loosing traction. I think it is becouse of the GoodYear Eagle RSA's on them. I have had simular experance with these same tires on another car. I think also the tires should be a bit wider and have a Z rating rather then a V. This ought to eliminate the rear from slipping.
I would like to know your opinion on this. The tire size I have selected would be a set of 225/45-17. This will make the speedo only .4% too fast. Were when doing 60mph you are actually doing 59.8mph
This is my resourse for my information on tire size
